AidStream C++ API
Plugin Overview
qtivcomposer Plugin
The qtivcomposer plugin uses GPU hardware to merge multiple input video streams into a single output stream. Pad properties determine how the input buffers from each stream are composited into the output buffer.
| Attribute | Purpose |
| Position | Sets the X and Y placement of each input frame in the output image. |
| Crops | Optionally crops the source image. |
| Dimensions | Scales frames up or down and adjusts the resolution. |
| Rotate | Rotates a frame by right-angle increments. |
| Flip-horizontal / Flip-vertical | Controls how each input frame is mirrored in the composed output. |
| Alpha | Adds an alpha-blending value to a frame. |
| Z order | Controls layer stacking. By default, stacking follows sink pad creation order, such as sink_0, sink_1, and so on. |
| Property | Description |
name | Object name. - Access: read, write - Type: string - Default: "video_composer0" |
parent | Parent object. - Access: read, write - Type: GstObject |
engine | Backend engine used for conversion. - Access: read, write - Type: GstVideoConverterBackend- Default: 1, gles- 1: gles uses the OpenGLES-based converter- 2: fcv uses the FastCV-based converter- Note: the Qualcomm Computer Vision SDK ( fcv) backend is currently unsupported |
latency | Extra delay for live pipelines, allowing upstream elements more time to generate buffers. - Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
start-time-selection | Determines how output start time is selected. - Access: read, write - Type: GstAggregatorStartTimeSelection- Default: 0, zero- 0: zero starts at runtime 0- 1: first starts from the first observed input runtime- 2: set uses the start-time property |
start-time | Start time used when start-time-selection is set to set.- Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 18446744073709551615 |
background | Background color. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: unsigned integer - Range: 0 to 4294967295- Default: 4286611584 |
waylandsink Plugin
The waylandsink plugin is implemented on top of GStreamer's GstVideoSink class. It works with the Wayland Weston compositor, creates a window automatically, and renders incoming video frames into that window.
Qualcomm extends waylandsink with window-positioning support, a GBM-based zero-copy buffer backend, and an XDG shell backend.
In the current release, the x, y, width, and height properties are not supported.
name | Object name. - Access: read, write - Type: string - Default: "waylandsink0" |
sync | Synchronizes rendering to the pipeline clock. - Access: read, write - Type: boolean - Default: true |
max-lateness | Maximum lateness allowed before a buffer is dropped, in nanoseconds. -1 means unlimited.- Access: read, write - Type: 64-bit integer - Range: -1 to 9223372036854775807- Default: 20000000 |
qos | Emits QoS events upstream. - Access: read, write - Type: boolean - Default: true |
async | Transitions to PAUSED asynchronously.- Access: read, write - Type: boolean - Default: true |
ts-offset | Timestamp offset in nanoseconds. - Access: read, write - Type: 64-bit integer - Range: -9223372036854775808 to 9223372036854775807- Default: 0 |
enable-last-sample | Enables the last-sample property.- Access: read, write - Type: boolean - Default: true |
last-sample | The last sample received by the sink. - Access: read - Type: GstSample boxed pointer |
blocksize | Byte size of each buffer pull. 0 means default.- Access: read, write - Type: unsigned integer - Range: 0 to 4294967295- Default: 4096 |
render-delay | Extra sink-side render delay in nanoseconds. - Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
throttle-time | Interval between rendered buffers. 0 disables throttling.- Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
max-bitrate | Maximum rendered bitrate in bits per second. 0 disables the limit.- Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
show-preroll-frame | Controls whether preroll frames are rendered. - Access: read, write - Type: boolean - Default: true |
display | Wayland display name used for the connection if not supplied through GstContext.- Access: read, write - Type: string - Default: null |
xdg-shell | Uses the XDG shell protocol. - Access: read, write - Type: boolean - Default: true |
fullscreen | Controls fullscreen display. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: boolean - Default: false |
qtivsplit Plugin
The qtivsplit plugin uses GPU hardware to split one input video stream into multiple output streams. The number of streams is user-defined and matches the number of source pads.
Each source pad's mode property determines how the input stream is split.
| Mode | Description |
none | Copies incoming frames from the sink pad to every source pad. Additional color conversion and scaling may be performed based on the negotiated GstCaps. |
single-roi-meta | Checks whether GstVideoRegionOfInterestMeta is present in the input buffer. The number of source pads must match the maximum expected ROI metadata entries per GstBuffer. If there are too few pads, unmatched ROI metadata is ignored. |
batch-roi-meta | Processes ROI metadata attached to the buffer. Unlike single-roi-meta, each metadata entry is forwarded as an individual buffer. |
name | Object name. - Access: read, write - Type: string - Default: "videosplit0" |
engine | Backend engine used for conversion. - Access: read, write - Type: GstVideoConverterBackend- Default: 1, gles- 1: gles uses the OpenGLES-based converter- 2: fcv uses the Qualcomm Computer Vision SDK-based converter- Note: the Qualcomm Computer Vision SDK ( fcv) backend is currently unsupported |
qtivtransform Plugin
The qtivtransform plugin uses GPU hardware to scale, flip, rotate, crop, and color-convert input YUV or RGB frames according to element properties.
| Destination | Sets the X and Y position of the input frame in the output image and defines the output dimensions. |
| Crop | Optionally crops the source frame. |
| Rotate | Rotates the frame by right-angle increments. |
| Flip-horizontal / Flip-vertical | Mirrors the frame horizontally or vertically. |
If no transformation properties are specified on the source pad caps, the plugin negotiates capabilities identical to the input stream and runs in pass-through mode until the parameters change.
The plugin uses Qualcomm's IB2C library on the Adreno GPU to perform these transformations. The library is wrapped by the custom GstC2dVideoConverter abstraction, which exposes APIs for creating, configuring, and processing input and output buffers.
The custom GstImageBufferPool can allocate either GBM or ION output buffers, depending on downstream negotiation:
- GBM allocation uses Qualcomm's
libgbmimplementation. - ION allocation is performed by issuing IOCTL commands to the kernel.
name | Object name. - Access: read, write - Type: string - Default: "videotransform0" |
flip-horizontal | Mirrors the frame horizontally. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: boolean - Default: false |
flip-vertical | Mirrors the frame vertically. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: boolean - Default: false |
rotate | Rotates the frame. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: GstVideoTransformRotate- Default: 0, none- 0: none- 1: 90CW- 2: 90CCW- 3: 180 |
crop | Input crop rectangle in the format [X, Y, WIDTH, HEIGHT]. - Note: this property does not support time synchronization. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: array of gint-typed GstValue entries |
destination | Output destination rectangle in the format [X, Y, WIDTH, HEIGHT]. - Access: read, write; modifiable in NULL, READY, PAUSED, and PLAYING- Type: array of gint-typed GstValue entries |
qtisocketsink Plugin
The qtisocketsink plugin sends GstBuffer objects backed by file descriptors (FDs) to other processes through UNIX domain sockets. qtisocketsrc is the corresponding receiving element.
qtisocketsink requires a UNIX domain socket file with the .sock suffix. That file is passed through the socket property so the FD can be transferred.
Buffers received from other processes are tracked through reference counting. The counter is incremented or decremented as buffers are sent or returned through the socket.
Some commonly used qtisocketsink settings are listed below.
| Setting | Description |
async | When set to false, the socket transitions to PAUSED asynchronously. |
max-lateness | Maximum lateness allowed before a buffer is dropped, in nanoseconds. |
max-bitrate | Maximum rendered bitrate in bits per second. |
name | Object name. - Access: read, write - Type: string - Default: "fdsocketsink0" |
max-lateness | Maximum lateness allowed before a buffer is dropped. -1 means unlimited.- Access: read, write - Type: 64-bit integer - Range: -1 to 9223372036854775807- Default: -1 |
qos | Emits QoS events upstream. - Access: read, write - Type: boolean - Default: false |
ts-offset | Timestamp offset in nanoseconds. - Access: read, write |
last-sample | Last sample received by the sink. - Access: read - Type: GstSample boxed pointer |
socket | Path to the UNIX domain socket. - Access: read, write; only modifiable in NULL or READY- Type: string - Default: null |
qtisocketsrc Plugin
The qtisocketsrc plugin receives FD-backed GstBuffer objects from another process through a UNIX domain socket, typically from a qtisocketsink element.
The plugin requires a socket file with the .sock suffix. After the connection is established, it polls or waits for incoming GstBuffer objects and constructs buffer blocks from the received frame data.
Common buffer-related settings include:
blocksize: byte size of each read operation.num-buffers: number of buffers pushed downstream before EOF is sent.
name | Object name. - Access: read, write - Type: string - Default: "fdsocketsrc0" |
blocksize | Byte size of each read operation. -1 means default.- Access: read, write - Type: unsigned integer - Range: 0 to 4294967295- Default: 4096 |
num-buffers | Number of buffers output before EOS is sent. -1 means unlimited.- Access: read, write - Type: integer - Range: -1 to 2147483647- Default: -1 |
typefind | Runs type finding before negotiation. Deprecated and currently non-functional. - Access: read, write, deprecated - Type: boolean - Default: false |
do-timestamp | Applies the current stream time to outgoing buffers. - Access: read, write - Type: boolean - Default: false |
timeout | Socket connection timeout. - Access: read, write; only modifiable in NULL or READY- Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
v4l2h264dec Plugin
The v4l2h264dec plugin decodes video streams through the V4L2 API. On supported platforms, it uses the hardware H.264 decoder to provide hardware-accelerated H.264 decoding.
In the current release, only capture-io-mode and output-io-mode are writable. Both properties can only be used together with (5) dmabuf-import - GST_V4L2_IO_DMABUF_IMPORT.
automatic-request-sync-point-flags | Flags used when requesting sync points automatically. - Access: read, write - Type: GstVideoDecoderRequestSyncPointFlags- Default: 0x00000003, corrupt-output+discard-input |
automatic-request-sync-points | Requests sync points automatically when needed. - Access: read, write - Type: boolean - Default: false |
capture-io-mode | Capture-side I/O mode matched to the source pad. - Access: read, write - Type: GstV4l2IOMode- Default: 0, auto |
device | Device path. - Access: read - Type: string - Default: "/dev/video0" |
device-fd | Device file descriptor. - Access: read - Type: integer - Range: -1 to 2147483647- Default: -1 |
device-name | Device name. - Access: read - Type: string - Default: null |
discard-corrupted-frames | Drops frames marked as corrupted instead of outputting them. - Access: read, write - Type: boolean - Default: false |
extra-controls | Extra V4L2 control IDs for the device. - Access: read, write - Type: boxed GstStructure pointer |
max-errors | Maximum consecutive decoder errors allowed before reporting a stream error. - Access: read, write - Type: integer - Range: -1 to 2147483647- Default: 10 |
min-force-key-unit-interval | Minimum interval between forced key-unit requests, in nanoseconds. - Access: read, write - Type: unsigned 64-bit integer - Range: 0 to 18446744073709551615- Default: 0 |
name | Object name. - Access: read, write - Type: string - Default: "v4l2h264dec0" |
output-io-mode | Output-side I/O mode matched to the sink pad. - Access: read, write - Type: GstV4l2IOMode- Default: 0, auto |
qos | Handles QoS events from downstream. - Access: read, write - Type: boolean - Default: true |
v4l2h265dec Plugin
The v4l2h265dec plugin decodes video streams through the V4L2 API. On supported platforms, it uses the hardware H.265 decoder to provide hardware-accelerated H.265 decoding.
- V4L2 is the standard Linux interface for video devices and is responsible for video capture, encoding, and decoding.
- H.265 provides better compression efficiency than H.264, and hardware decoding reduces system resource usage.
GstVideoDecoderis the GStreamer base class that keeps the plugin aligned with standard decoding flows.
name | Object name. - Access: read, write - Type: string - Default: "v4l2h265dec0" |
v4l2h264enc Plugin
The v4l2h264enc plugin encodes video through the V4L2 API. On supported platforms, it uses the hardware H.264 encoder to provide hardware-accelerated H.264 encoding.
- V4L2 is the standard Linux interface for video devices and is responsible for video capture and encoding.
- Hardware H.264 encoding improves throughput while reducing CPU usage compared with software encoding.
GstVideoEncoderis the base class that keeps the element compatible with standard GStreamer encoding flows.
device | Device path. - Access: read - Type: string - Default: "/dev/video1" |
name | Object name. - Access: read, write - Type: string - Default: "v4l2h264enc0" |
| Control | Type | Description |
horizontal_flip | boolean | value=0 by default; flags=execute-on-write |
vertical_flip | boolean | value=0 by default; flags=execute-on-write |
rotate | integer | min=0, max=270, step=90, value=0; flags=execute-on-write and modify-layout |
v4l2h265enc Plugin
The v4l2h265enc plugin encodes video through the V4L2 API. On supported platforms, it uses the hardware H.265 encoder to provide hardware-accelerated H.265 encoding.
- Hardware H.265 encoding provides better compression efficiency than H.264 while reducing CPU usage through dedicated hardware blocks.
name | Object name. - Access: read, write - Type: string - Default: "v4l2h265enc0" |
C++ API Overview
| Structure | Member | Type | Description |
Image | data | const char * | Pointer to the image data buffer. |
data_mask | const char * | Pointer to the mask buffer. Reserved. | |
stream_id | string | Unique stream identifier. Required and useful in multi-threaded scenarios. | |
width | int | Image width. | |
height | int | Image height. | |
width_padding | int | Width padding. Used only on 6490 QL. | |
height_padding | int | Height padding. Used only on 6490 QL. | |
size | uint64_t | Buffer size occupied by the image data. | |
fps | double | Frame rate. | |
idx | uint64_t | Frame counter. | |
frame_time | string | Frame timestamp. Used only on 6490 QL. | |
enable_mask_drawing | bool | Whether mask drawing is enabled. | |
pipe_status | int | Pipeline status. | |
stride | int | Stride value. | |
scanline | int | Scanline value. | |
pts | int64_t | Presentation timestamp. | |
format | string | Image format. |
| Public Function | Description |
void clogger(const char* path_and_prefix) | Creates log files and sets the file path and filename prefix. |
void set_log_level(GSTLogLevel log_level) | Sets the log level. |
typedef function<int8_t(const Image &)> GetImageCB | Callback type used by stream-start APIs to provide image buffers to application code. |
int start_stream(string stream_id, GetImageCB &cb) | Starts a stream by stream_id. This is the recommended interface for most applications. |
int start_stream_input_file(string file_path, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) | Starts a file-based stream. |
int start_stream_input_rtsp(string rtsp_addr, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) | Starts an RTSP stream. |
int start_stream_input_rtmp(string rtmp_addr, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) | Starts an RTMP stream. |
| Enum | Member | Type | Description |
GSTLogLevel | SINFO | uint8_t | Info log level. |
SWARNING | uint8_t | Warning log level. | |
SERROR | uint8_t | Error log level. | |
SDEBUG | uint8_t | Debug log level. | |
SOFF | uint8_t | Logging disabled. | |
StreamType | EMPTY | uint8_t | No output protocol. |
WAYLANDSINK | uint8_t | Wayland display output. | |
RTSPSINK | uint8_t | RTSP output. | |
RTMPSINK | uint8_t | RTMP output. | |
MP4 | uint8_t | MP4 file output. |
Image Structure
Image describes frame metadata, buffer pointers, and pipeline-side image properties.
data_mask | const char * | Pointer to the mask data buffer. Reserved. |
Unless otherwise stated, all definitions belong to the Aidlux::AidStream namespace:
using namespace Aidlux::AidStream;Return value convention: All return values in the following APIs follow the AidStreamStatusCode enum.
0meansAS_OK(success); failures may return specific error codes ranging from-1to-8, such as-4(pipeline creation failed) or-5(stream not running).
Start a Stream by Stream ID
| API | int start_stream(string stream_id, GetImageCB &cb) |
| Description | Starts a stream by stream_id. Stream definitions are read from /usr/local/share/aidstream-gst/conf/aidstream-gst.conf. Each stream_id must be unique. This is the strongly recommended interface for production use. |
| Parameters | stream_id: unique stream configuration identifier.cb: callback function. See GetImageCB.For configuration details, see AidStream configuration reference. |
| Return Value | 0 for success, -1 for failure |
Example:
int res = start_stream("stream1", my_cb);Start a File Stream
| API | int start_stream_input_file(string file_path, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) |
| Description | Starts a file-based stream without relying on a configuration file. |
| Parameters | file_path: source MP4 file.cb: callback function.display_type: output type (default: EMPTY).target_path: output target path (default: "").width: output width (default: 640, effective only in WAYLANDSINK mode).height: output height (default: 480, effective only in WAYLANDSINK mode).stream_id: unique stream identifier (default: "empty" auto-generated). |
Example:
int res = start_stream_input_file("./test.mp4", my_cb, StreamType::WAYLANDSINK, "<output-stream-url>/aidstream-gst-test-6");Start an RTSP Stream
| API | int start_stream_input_rtsp(string rtsp_addr, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) |
| Description | Starts an RTSP stream without relying on a configuration file. |
| Parameters | rtsp_addr: source RTSP address.cb: callback function.display_type: output type (default: EMPTY).target_path: output target path (default: "").width: output width (default: 640, effective only in WAYLANDSINK mode).height: output height (default: 480, effective only in WAYLANDSINK mode).stream_id: unique stream identifier (default: "empty" auto-generated). |
Example:
int res = start_stream_input_rtsp("<input-stream-url>/h264/ch1/main/av_stream", my_cb, StreamType::RTSPSINK, "<output-stream-url>/aidstream-gst-test-3");Start an RTMP Stream
| API | int start_stream_input_rtmp(string rtmp_addr, GetImageCB cb, StreamType display_type, string target_path, int width, int height, string stream_id) |
| Description | Starts an RTMP stream without relying on a configuration file. |
| Parameters | rtmp_addr: source RTMP address.cb: callback function.display_type: output type (default: EMPTY).target_path: output target path (default: "").width: output width (default: 640, effective only in WAYLANDSINK/RTSPSINK mode).height: output height (default: 480, effective only in WAYLANDSINK/RTSPSINK mode).stream_id: unique stream identifier (default: "empty" auto-generated). |
Example:
int res = start_stream_input_rtmp("<input-stream-url>/h264/ch1/main/av_stream", my_cb, StreamType::EMPTY, "<output-stream-url>/aidstream-gst-test-2");Create Logs with clogger
| API | void clogger(const char* path_and_prefix) |
| Description | Creates log files and sets the file path and filename prefix. |
| Parameters | path_and_prefix: log filename with path, for example "./aidclog_aidstream_". |
| Return Value | None |
Example:
Aidlux::AidStream::clogger(log_path);Set the Log Level
| API | void set_log_level(GSTLogLevel log_level) |
| Description | Sets the log level. |
| Parameters | log_level: a GSTLogLevel enum value. See GSTLogLevel. |
Example:
Aidlux::AidStream::set_log_level(GSTLogLevel::SINFO);GSTLogLevel Enum
StreamType Enum
ScenarioType Enum
| Member | Type | Value | Description |
Pulling_A | int | 0 | Read stream → (custom frame processing). |
PullingEncode_B | int | 1 | Encode stream → stream output. |
PullingInferenceOutput_C | int | 2 | Read stream → (decode) → AI processing → output results. |
PullingInferenceEncode_D | int | 3 | Read stream → (decode) → AI processing → stream output. |
PullingMultiCompInference_E | int | 4 | Merge multiple streams, run inference (Qualcomm QNN via qtimlqnn). |
PullingMultiComp_F | int | 5 | Merge multiple streams into one. |
PullingMultiCompInference_G | int | 6 | Merge multiple streams, run inference, save as MP4, and push RTSP. |
PullingMultiCompInference_H | int | 7 | Merge multiple streams, run inference, save as MP4, and push RTSP. |
TaskType Enum
MultiVideoDecode | int | Multi-video decoding task. |
MultiVideoEncode | int | Multi-video encoding task. |
VideoDecode | int | Video decoding task. Required for all stream pull operations. |
InferenceCB | int | Inference callback task. Invokes inference within the callback. |
VideoEncode | int | Video encoding task. Required when encoding is needed. |
CustomCB | int | Custom callback task. For user-defined callback operations. |
InferenceQTI | int | QTI inference task using the Qualcomm qtimlqnn plugin. |
AidStreamStatusCode-Enum
AS_OK | int | 0 | Success. |
AS_ERR_INVALID_PARAM | int | -1 | Invalid parameter. |
AS_ERR_STREAM_EXISTS | int | -2 | Stream already exists. |
AS_ERR_STREAM_NOT_FOUND | int | -3 | Specified stream not found. |
AS_ERR_PIPELINE_CREATE | int | -4 | Pipeline creation failed. |
AS_ERR_NOT_RUNNING | int | -5 | Stream is not in running state. |
AS_ERR_NOT_SYNCED | int | -6 | Stream is not synchronized. |
AS_ERR_PUSH_BUFFER | int | -7 | Buffer push failed. |
AS_ERR_INTERNAL | int | -8 | Internal error. |
HevcAuInfo Structure
HevcAuInfo describes the parsed HEVC access unit information.
| Member | Type | Default | Description |
has_vps | bool | false | Whether the AU contains a VPS (Video Parameter Set). |
has_sps | bool | false | Whether the AU contains an SPS (Sequence Parameter Set). |
has_pps | bool | false | Whether the AU contains a PPS (Picture Parameter Set). |
is_keyframe | bool | false | Whether the AU is a keyframe. |
has_slice | bool | false | Whether the AU contains slice data. |
Callback Function: GetImageCB
| API | typedef std::function<int8_t(const Image &)> GetImageCB |
| Description | Callback type used by stream-start APIs to hand image buffers to application code. Users implement the callback themselves; the SDK only defines the callback signature. |
| Parameters | The callback receives an Image instance containing buffer pointers, dimensions, frame rate, and related metadata. See Image. |
| Return Value | User-defined |
Example:
int8_t my_get_img_cb(const Image &img)
}AidStream Configuration Reference
When using int start_stream(string stream_id, GetImageCB &cb), input and output streams can be configured through /usr/local/share/aidstream-gst/conf/aidstream-gst.conf.
Requirements:
- The configuration file must be in JSON format.
- Parameters marked as required must be provided.
- Parameter names are case-sensitive.
The overall JSON structure is as follows:
"streams": [ // Root key: array of stream configurations (required)
"streamsId": "1", // Stream-level: unique stream identifier (required, matched with start_stream's stream_id)
"pStreamId": "p_1", // Stream-level: parent stream ID (optional, for linking parent-child streams)
"properties": { // Properties-level: stream-specific configuration parameters
"inputType": "rtsp",
}Parameters by hierarchy:
| Level | Parameter | Type | Required | Description |
| Root | streams | array | Yes | Array of stream configurations, each element defines one stream. |
| Stream | streamsId | string | Yes | Unique stream identifier, corresponds to the stream_id parameter of start_stream(). |
| Stream | pStreamId | string | No | Parent stream ID, used to link parent-child streams (e.g., splice scenarios). |
| Properties | inputType | string | Yes | Input protocol type. Supported: rtsp, rtmp, file, usbcam, splice. |
| Properties | inputAddr | string | Yes | Input stream address (can be omitted for usbcam/splice types). |
| Properties | outputType | string | Yes | Output protocol type. Supported: rtsp, wayland, mp4, empty (empty outputs to fakesink without pushing or rendering). |
| Properties | outputAddr | string | Yes | Output stream address. |
| Properties | decodeType | string | No | Hardware decode format. Supported: H264, H265. Default: H264. |
| Properties | encodeType | string | No | Hardware encode format. Supported: H264, H265. Default: H264. |
| Properties | audio | bool | No | Enables audio. Default: false. |
| Properties | saveMp4 | bool | No | Saves output as MP4 file (width/height required when enabled). |
| Properties | outputFile | string | No | MP4 output file path. Only takes effect when saveMp4 is true. Default: /tmp/saved_output.mp4. |
| Properties | width | int | No | Output video width (required when saveMp4 or networkPush is enabled). |
| Properties | height | int | No | Output video height (required when saveMp4 or networkPush is enabled). |
| Properties | fps | int | No | Output frame rate (required when networkPush is enabled). |
| Properties | rollingsave | bool | No | Enables rolling recording. Default: false. |
| Properties | rollingFps | int | No | Playback frame rate for rolling-save MP4 files. Default: -1 (StreamProperty default is 30). |
| Properties | networkPush | bool | No | Enables network pushing (width/height/fps required when enabled). |
Placeholder conventions:
<input-stream-url>: for example,rtsp://admin:aidlux123@192.168.110.234:554<output-stream-url>: for example,rtsp://192.168.111.115:8554
Update these addresses according to your local network environment.
Reference example:
"streams": [
"streamsId": "1",
"properties": {
"outputType": "rtsp",
"decodeType": "H264",
"encodeType": "H264"
}StreamIns Structure
StreamIns is used as the parameter to start() and exposes a richer stream-configuration model for programmatic startup.
stream_id | string | "empty" | Unique stream identifier. |
p_stream_id | string | "empty_p" | Parent stream identifier, used to link parent-child stream relationships. |
inputType | string | "" | Input stream type: rtsp, rtmp, file, or usbcam. |
inputAddr | string | "" | Input source address. |
outputType | string | "" | Output type: rtsp, wayland, mp4, or empty. |
outputAddr | string | "" | Output target address. |
decodeType | string | "H264" | Hardware decode format: H264 or H265. |
encodeType | string | "H264" | Hardware encode format: H264 or H265. |
audio_switch | bool | false | Enables audio. |
save_mp4 | bool | false | Saves output as MP4. |
network_push | bool | false | Enables network push output. When enabled, separate processing is triggered. |
output_file | string | "/tmp/saved_output.mp4" | Output path for MP4 files. |
width | int | 0 | Video width. |
height | int | 0 | Video height. |
fps | int | 0 | Video frame rate. |
rolling_save | bool | false | Enables rolling recording. |
rollingFps | int | -1 | Frame rate used for rolling recording MP4 playback. |
manual_rebuild | bool | true | Whether to manually reconnect on EOS or error (true = manual, false = auto). |
AidStreamEngine Class
AidStreamEngine provides a newer engine API driven by ScenarioType and TaskType.
| Method | Description |
AidStreamEngine(ScenarioType scenario_type) | Constructor. Initializes the engine with a scenario type. |
~AidStreamEngine() | Destructor. |
int add_task(TaskType task_type, std::unordered_map<std::string, std::string>& config) | Adds a processing task. Returns 0 on success, -1 on failure. |
void set_callback(TaskType task_type, GetImageCB &callback) | Sets the callback function for the specified task type. |
int start() | Starts the engine. Returns 0 on success. Note: only PullingMultiCompInference_E/F/G/H scenarios are actually processed; other scenario types silently return 0 with no operation. |
static void stop() | Stops the engine. This is a static method. |
Start a Stream with StreamIns
| API | int start(StreamIns &stream_ins, GetImageCB &cb) |
| Description | Starts a stream by configuring all stream parameters programmatically without a configuration file. |
| Parameters | stream_ins: stream configuration structure containing the full stream definition.cb: callback function. |
| Return Value | 0 for success, -1 or another AidStreamStatusCode value for failure |
Refer to [AidStreamStatusCode Enum](#aidstreamstatuscode-enum)Stop and Release a Stream
| API | void gstreamer_pipeline_shutdown(std::string stream_id = "all_stream") |
| Description | Stops a stream. You can stop a single stream by stream_id, or stop all streams by passing "all_stream". |
| Parameters | stream_id: target stream ID or "all_stream". |
Retrieve Rolling Recording Files
| API | int get_rolling_save_video(std::string stream_id, std::string output_video, int delay_seconds = 5) |
| Description | Retrieves the MP4 file currently being generated by the rolling-recording pipeline, merging and exporting a video clip of the specified duration from the rolling buffer. Useful for persisting video clips after exception or event detection. |
| Parameters | stream_id: stream identifier.output_video: output video file path.delay_seconds: base delay in seconds before retrieval (default: 5; actual wait time is delay_seconds + 5 seconds). |
USB Camera Interface
| API | int start_stream_input_usbcam(StreamIns &stream_ins, GetImageCB cb, StreamType display_type, std::string stream_id) |
| Description | Starts stream processing from a USB camera. |
| Parameters | stream_ins: USB camera initialization settings.cb: callback function.display_type: output stream type.stream_id: unique stream identifier. |
Splice Stream APIs
The splice-stream APIs are intended for raw-stream stitching and mixed display scenarios.
| API | int start_splice_stream(std::string stream_id, GetImageCB &cb) |
| Description | Starts decoding and output for a splice stream. |
| Parameters | stream_id: unique stream identifier.cb: callback function. |
| API | int stop_splice_stream(std::string stream_id) |
| Description | Stops a splice stream. |
| Parameters | stream_id: unique stream identifier. |
| API | int decode_put_frame_splice(const uint8_t *data, size_t size, const std::string &stream_id, int64_t pts = -1, bool is_keyframe = false) |
| Description | Pushes a video frame into the splice buffer. |
| Parameters | data: video frame data pointer.size: data size.stream_id: unique stream identifier.pts: presentation timestamp (default: -1).is_keyframe: whether this is a keyframe (default: false). |
| API | HevcAuInfo parse_hevc_au_info_splice(const uint8_t *data, size_t size) |
| Description | Parses H.265 (HEVC) access unit metadata before splicing. |
| Parameters | data: HEVC data pointer.size: data size. |
| Return Value | HevcAuInfo structure containing VPS/SPS/PPS/keyframe/slice information. |
Get Stream Properties
| API | int get_properties(std::string stream_id, StreamIns &stream_obj) |
| Description | Reads the stream configuration properties for the specified stream_id from the configuration file and populates the StreamIns object. |
| Parameters | stream_id: unique stream identifier.stream_obj: reference to a StreamIns object to receive the configuration. |
Get Stream Status
| API | int get_stream_status() |
| Description | Returns the current running status of the stream. Returns 1 when the stream is actively running. |
| Parameters | None |
| Return Value | 1: stream is running, 0: stream is idle, -1: uninitialized |
Get Image Data
| API | cv::Mat get_data(int height, int width, char* data) |
| Description | Converts raw image data of the specified height and width into an OpenCV cv::Mat object in CV_8UC3 format. |
| Parameters | height: image height.width: image width.data: pointer to image data buffer. |
| Return Value | OpenCV cv::Mat object |
V4L2 Image Conversion
Converts V4L2-sourced image data to OpenCV BGR-format cv::Mat objects.
| API | int v4l2_get_mat(cv::Mat &destMat, Image img) |
| Description | Converts image data from Image into a BGR-format cv::Mat, cropping to the actual dimensions (removing padding). Designed for the 6490 QL platform. |
| Parameters | destMat: output BGR-format matrix.img: Image object containing buffer data and dimensions. |
| Return Value | 0 for success, -1 for failure (empty data) |
| API | int v4l2_get_mat_ori(cv::Mat &destMat, Image img) |
| Description | Converts image data from Image into a BGR-format cv::Mat (preserves padding, no cropping). Designed for the 6490 QL platform. |
Start Audio Stream
| API | int start_audio_stream(std::string stream_id, GetImageCB &cb) |
| Description | Starts audio stream processing, used alongside video streams. |
Start Split Stream
| API | int start_split_stream(std::string stream_id_1, GetImageCB &cb1, std::string stream_id_2, GetImageCB &cb2) |
| Description | Starts a single input stream that splits into two output streams. Both stream_id values must share the same parent stream identifier (p_stream_id) and input configuration. |
| Parameters | stream_id_1: first output stream identifier.cb1: callback for the first stream.stream_id_2: second output stream identifier.cb2: callback for the second stream. |
