AidConnect Android API ​
[TOC]
class AidConnect ​
Used for SDK initialization and log output control.
Public Member Functions ​
initialize() ​
java
public static AidConnect initialize(Application mApplication, boolean logDebug, AidConnectCallback aidConnectCallback)
  • Parameters
Parameter NameTypeDefaultDescription
mApplicationApplication-Android Application object
logDebugboolean-SDK log switch. true: prints all log levels; false: prints only error-level logs
aidConnectCallbackAidConnectCallback-Initialization callback
  • Return
TypeDescription
AidConnectReturns the AidConnect singleton instance
addChannelWithName(); ​
java
public static Set<String> addChannelWithName(String name, int size);
Creates a communication channel with the specified name and size, and returns the set of all channel names.
  • Parameters
nameString-User-defined channel name
sizeint-Channel size in MB
  • Return
TypeDescription
Set<String>Set of all channel names
removeChannelWithName(); ​
java
public static Set<String> removeChannelWithName(String name);
Removes the communication channel with the specified name and returns the set of all channel names.
  • Parameters
nameString-Name of the channel to remove
  • Return
TypeDescription
aidConnectWithName(); ​
java
public static synchronized AidConnect aidConnectWithName(String name);
Obtains the AidConnect instance for the specified channel, which is the core class for managing data interaction.
  • Parameters
nameString-Name of the channel to use
  • Return
TypeDescription
AidConnectAidConnect instance
setBytes(); ​
java
public boolean setBytes(byte[] bytes);
Writes data to the channel.
  • Parameters
bytesbyte[]-Byte array
  • Return
TypeDescription
booleanWhether the write was successful
getBytes(); ​
java
public byte[] getBytes(int len);
Reads data with the specified byte length.
  • Parameters
lenint-Number of bytes to read
  • Return
TypeDescription
byte[]The byte array read from the channel
getBytes(); ​
java
public byte[] getBytes();
Reads all data from the last write operation (length automatically matches the write length).
  • Return
TypeDescription
getBytes(); ​
java
public byte[] getBytes(byte[] bytes, int len);
Reads data into a pre-allocated byte array with the specified length.
  • Parameters
bytesbyte[]-Pre-allocated byte array of size len
  • Return
TypeDescription
release(); ​
java
public static synchronized int release();
Releases all resources.
  • Parameters
None
  • Return
TypeDescription
int0: success; non-zero: failure
setStateCallback(); ​
java
public static void setStateCallback(RemoteSDKStatusCallBack remoteSDKStatusCallBack);
Sets the service connection status listener callback to receive server-side state change notifications.
  • Parameters
remoteSDKStatusCallBackRemoteSDKStatusCallBack-Service status callback interface instance
  • Note
    The SDK has already set a default callback instance during initialization. Call this method only when custom listening is needed.
Last updated:
